WF45M5500AP Samsung Washer - warm settings on panel don't work
nigel_miguel
London
WF45M5500AP
Samsung
hello, my samsung washer wf45m5500ap/a5 only works on the cold settings.
What could it be? is it the mother board?
any help will be greatly appreciated.
thanks
Use a multimeter to check for 120 volts at the hot water inlet valve when its on the HOT water setting, if you get 120 volts and no HOT water is coming out, its bad.
Here's the hot water inlet valve for your model:
Water Inlet Valve DC62-30314K
There is a video in the part link to show you how to access it.
nigel_miguel
London
Hi Jake, i tested the inlet valve it gets power. If i select any of the RIGHT side functions of the dial (Normal, heavy duty, bedding, sanitize & allergen), the machine will turn off and flicker back on and flash the time remaining.
It doesn't even start the function selected. What could it be?
If the HOT water inlet valve is getting 120 volts and no HOT is coming out, then that water inlet valve is bad.
I'm not sure what could be the problem, Samsung machines are not popular in my area and I have never seen that problem before.
You may need to have Samsung come out about that issue.
nigel_miguel
London
Thanks Jake.
Can you point me to exact items? #1 & #3 have sub-sets in the pictures. Very much appreciate your assistance with this.
thanks again
