FIXED WFE540H0AS0 Oven will not heat above 350 degrees
Wx4usa
Alabama
Model
WFE540H0AS0
Oven will not heat above 350. I am not familiar with this model. Any help would be appreciated. :)
Can you go into more detail please.
How long does it take to get to 350?
If you set it at 450 what happens? The control does not accept 450 or the oven does not fire up anymore to get to 450?
I'd first ohm test your oven sensor. I use this multimeter myself: Multimeter DM10T
To ohm test the oven sensor: All you do is pull your range out from the wall, then unplug it, then remove the back access panel and you will see a little plastic connector that connects to your oven sensor, just unsnap that little plastic connector and take a ohm reading on it at room temperature per the video below.
Here's the oven sensor for your model:
Oven Sensor WPW10181986
[video=youtube_share;vWJOLFW2aw0]https://youtu.be/vWJOLFW2aw0[/video]
Wx4usa
Alabama
Turned out to be the bake element. I don’t work on these a lot. It’s hidden under a metal tray in the oven floor. Thanks Jake!
Excellent, glad it was just a bad bake element.:)
Here's the bake element for this model, in case others need it too:
Bake Element W10779716
