WFE540H0ES Not maintaining constant temperature
dtap98
fl
WFE540H0ES
Trying to bake cookies and oven is not maintaining constant temperature. Oven will reach 350 degrees but will take 1hr for cookies to bake, should not be more than 20 minutes. I am able to place hand in oven and feel very cooling temperatures. Will shut oven off, then set to 350 again, hit bake and wait for oven to heat up again. Did this until cookies finished baking. What is wrong and how do I fix this?
Let's first check your bake element, pull your range out from the wall, then unplug your range from the wall outlet, then watch this video to access it:
Check the back two bake element terminals to make sure it didn't short out there, if so order and replace it.
Then remove the cover from over the bake element per the video and see if your bake element has a hole in it, or any bad spots in it. If so, order and replace it.
If neither is the case, then you will need to ohm test it:
Here's the bake element for your model you can order if needed:
W10779716 Bake Element
dtap98
fl
Thanks for your help Jake. We followed your instructions and the element was fried!!! New element ordered and on it's way. Thanks again!!
Excellent, glad to hear you found it was the bake element. Let us know how it goes after you replace it.
