FIXED WFG540H0AH1 Whirlpool oven won't ignite
Brian Van Dine
Illinois
WFG540H0AH1
Hello. We are frustrated with our not so old oven as it has a history of not wanting to ignite. The symptoms are it tries to ignite by making 4 or 5 clicks.
We can tell when it succeeds because there is a whooshing noise at ignition. However, when it doesn't ignite it behaves like a flooded engine and we can smell gas when we open the door.
The stove burners and broiler burners all work - only bake fails and does so frequently. I ran through the error code sequence should the following help with the diagnosis : 01, 1196, 600d, 92db,5312, U 30, 139
Hi Brian,
You posted the Age as Less than 1 year old, is that correct? If so, it's best to have Whirlpool come out under warranty to fix this for you.
Here's the parts diagram for your model: Parts for Whirlpool WFG540H0AH1 Manifold Parts
#11 is your bake burner tube
#13 is your bake igniter that mounts onto the bake burner tube
If you bend the bracket a little closer to the electrode and have a good clean surface, it should work fine.
Here's the oven bake ignitor for your model:
WPW10324262 Igntr-Oven
Brian Van Dine
Illinois
Actually, the oven is about 3 years old. Re: your answer, are you saying that the repair may need nothing more than bending the bake burner bracket closer to the starter electrode? Or, do you recommend new parts, as well? Thanks.
That's correct Brian, I've been on many service calls, and that's exactly what I did and never heard from the customer again.:)
No, unless bending it closer does not fix it.
Brian Van Dine
Illinois
O.K. Thanks. I took out the two screws that attached the oven bottom plate and removed the plate, thus, exposing the burner assembly. I bent the igniter assembly housing towards the burner tube.
I have tried igniting the oven subsequently about six times. Five times it worked on the first or second click. Only one time did it not light after running through all of its clicks.
I waited to see if the automatic re-click would start it, it tried to but it failed, too.
I opened the door to vent gas for a minute, then tried starting the oven again. This time it started right away. So, the fix isn't flawless but it seems to be much improved. Just tried to ignite it one more time for good measure and it worked.
Ok, glad to hear its much better!
tt5354
california
Hi Jake,
This if very informative. I am having a similar problem where the oven works intermittently. How close do you recommend bending the bracket to the electrode?
Do you have the exact same model number WFG540H0AH1?
A inch or two away from the burner.
