WFMC1001UC/07 Bosch Washer won't start
tseibring
Sheldon, Illinois, United States
WFMC1001
Bosch
I have a Bosch washer. When you start it, the door locks and water starts going in. After that all I can here is a click coming from the control module. I thought it was bad so I replaced it with a new one. Still doing the same thing. Could the capacitor be bad? Any help would be appreciated. Thanks
No, that capacitor is the interference capacitor, if that was bad the machine would be dead and nothing would turn on.
Since its filling with water and you are hearing a click from the control module, then I'd check for voltage at the electrical connector that connects to the motor.
--->Check voltage at motor connectors when motor should be running. If low or no voltage, replace faulty motor control board. If voltage is 120V, check motor resistance (when washer de-energized). If motor is OK, replace faulty motor control board.
Here's the motor control board for your model:
Motor Control Board 00675654
You said you replaced the control module.
This is the control module for this model:
Control Module 00666537
So if you meant motor control board, then you'll need to check the voltages like I mentioned.:)
Ok, so which part did you already replace? The motor control board or the control module?
Please clear me up, I'm still confused.
After checking the motor voltage, I found it to be bad.
So the first motor control board was bad? Then the 2nd one you just replaced was good?
A new motor?
The motor shows to be No Longer Available: 00436478
Mike L
virginia
They tried to sell me a new motor a few years ago but the brushes inside are a wear item. Very easy to replace. Mine was a 2006 model like yours.
That's good to know Mike, I'm not that familiar with Bosch motors and I was not aware of that.
