WFVC3300UC/19 Bosch loud washer on the spin cycle
scottkeltner
Wisconsin
WFVC3300UC
Bosch
First time tonight the washer started making a loud noise on the spin cycle. Only on the spin cycle though. Fills and drains just fine. I’m thinking it’s the tub bearing but don’t want to jump to conclusions. I removed the load and spun the drum manually and it sounds to me like a bad bearing. Amy thoughts? Worth repairing or buy a new one? Thanks in advance!
Bosch WFVC3300UC/19
Hi Scott,
Yes, its most likely the bearing went out.
Here's the parts diagram: Parts for Bosch WFVC3300UC/19: Drum Assembly Parts
It looks like the bearing only comes when you order the outer tub assembly #341 which it says No Longer Available.
