FIXED WFW5090GW Whirlpool washer (W10856086-RevB) making weird sounds
jgordon00
New York
WFW5090GW
Less than 1 year
I'm hearing strange sounds from my Whirlpool WFW5090GW (W10856086 RevB) washing machine.
Typically before it gets into the spin cycle:
https://youtu.be/3XIGUZD6y1Y
The washer is less than a year old so I'm concerned about an issue surfacing so early in the life of the product. Any ideas what's causing the issue?
Josh
Hi Josh,
You will need to have Whirlpool come out to see what's going on, you have a 1 yr. warranty on it, don't try to fix it yourself or they will void your warranty.
Contact Whirlpool at 1-866-698-2538.
jgordon00
New York
Thanks - that was definitely in the plan but I really trust your wisdom here. Any sense of what could be the issue before I get into it with Whirlpool?
Josh
Yes Josh,
Sounds like something is possibly in the drain pump, or the drain pump bearing is bad.
You Bet!
jgordon00
New York
You're the man! Had the repair today and sure enough, the water pump was damaged because several metal shirt collar stays were caught inside, among other debris. The repair guy popped out the old pump, put in a new one and all is right again.
Appreciate your suggestions and guidance, as always!
Josh
Excellent Josh, glad to hear that.:)
Here's the water pump for this model in case others need too: W11046209 Pump-Water
