tuxboy
- WFW70HEBW0
- Whirlpool
- 6-10 years
Hello everyone, I need help determining which part I should replace.
I have a Whirlpool Duet Washer (WFW70HEBW0) that makes a terrible noise during the spin cycle. It still works fine, but it sounds like the washer is going to go through the wall! I attached a link to an audio clip so you can hear for yourself -- at the end of the clip, it sounds normal again (https://drive.google.com/drive/folders/1QixWa7EaY__k9UccahjeH_dMmXn2STYz?usp=sharing).
I removed the back cover and checked the four shocks -- all are in good shape. I also checked the spider arm, which seems to be solid and not cracked or broken.
So my question is which part do I need to replace?
Are there bearings on the rotor/stator combo that need to be replaced? Probably not, since it sounds okay during all the wash cycles.
From reading this forum, I know there are bearings in the tub, but can the bearings be replaced separately or do I need to replace the whole tub assembly?
Also, @Jake , I know you mentioned that the tub and/or bearings may have a 10 year warranty. How can I determine if mine is covered?
Thanks in advance for your help!
BTW, I also had a dryer problem that I was about to post, but found the Technician's Guide on this forum and ran through all the tests -- turns out to be a bad thermal fuse! This is now my Go-To forum for all things appliance related, and I love the videos on RepairClinic!
~ TuxBoy
~ TuxBoy
