suprnova74
- WFW72HEDW0
- Whirlpool
- 1-5 years
I have a 5 year old Duet WFW72HEDW0 and it just doesn't fill sufficiently. I understand it's supposed to use minimal water, but when it is finished filling, if I stop the washer and move the clothes, there is no water in the bottom of the drum for the clothes to tumble through. After reading some service manuals, it states there should be between 2 and 5 inches of water in the bottom.
As a test, I paused the washer after it was done filling initially, and poured water in manually until it was a respectable level. (about 2-3 inches visible at the front of the drum) which was about 2 or so gallons. right when i was about to close the door and continue, it threw an F8 code and auto-drained the tub. I guess the sensor detected what it perceived as too much water.
In any event, I unfortunately cannot determine how to adjust the water level. The pressure sensor doesn't have an adjustment screw like some models have. I thought I read somewhere that adjusting the vacuum hose length may adjust the water level, but I was unsure if it was to lengthen or shorten it.
As of right now, the clothes essentially just get heavily wet but don't have any water to tumble through.
