FIXED WFW75HEFW0 Whirlpool Front loader - Grinding before spinning and clanking sound when direction changes
drdavidge
NJ
WFW75HEFW0
Hi, our Whirlpool WFW75HEFW0 front load washing machine just started to make some strange sounds. There is a loud grinding sound that goes on for about 5-10 seconds that happens a few minutes before the spin cycle starts. It happens twice during a normal cycle, first around the 41 minute mark and second around the 13 minute mark. I have also noticed a louder than usual clank sound when the drum changes direction while the machine is doing its normal wash cycle. The cycle goes on and does fully complete but now I've just started to hear sounds while spinning too. Any thoughts on what is causing this and how to fix it?
I've taken a video and included it here:
Thanks all
Yes, I heard it.
I'd first check the rotor bolt and see if its loose.
Here's the rotor bolt:
Screw W11253212
This video gives you the general idea of how to access it:
drdavidge
NJ
Thanks. Yesterday I did hear some sort of clank (like a bolt dropping) while on the spin cycle and that's when the spin cycle started becoming noisy. Unfortunately its so hard to access the back of the machine so I haven't had a chance to check it out yet. Would a local store have that in stock somewhere? Would like to have it in hand quickly if it does turn out to be that but also be able to return it easily.
Just a local appliance parts store where they only sell appliance parts.
drdavidge
NJ
Thanks. Any thoughts on any other things it could be? Just wanted to be prepared whenever we move this as it is not easy to access!
Possibly the drain pump, on this model you have to access it from the back. Unplug your washer first.
Drain Pump WPW10605427
Here's the video to access it:
Your Maytag is identical to the Whirlpool washer. Whirlpool owns Maytag.
Once you access it, you will see the filter cap handle that you can unscrew off and remove the drain pump filter to clean it.
The filter cap handle is in the front of it, so you will need to reach your hand to very front of it and grab the handle and it unscrews off counterclockwise
drdavidge
NJ
It was the screw. You nailed it. The bolt is stuck inside though and I’ve been struggling with a screw extractor and a cordless drill for a while now. Any tips on that?
You mean the rotor bolt?
drdavidge
NJ
Yep it was that. I got it out and replaced it and then it was fine. But about 20 washes since and its happening again, seems like the bolt keeps getting loose. I guess I should use some sort of screw loctite?
