- WFW8300SW05
- Whirlpool
- 6-10 years
First of all I would like to say hi. I came across this forum while trying to get a handle on our washing machine woes. I like the way questions are answered and there seem to be a lot of happy forum users. I have done a forum search of our problem but wanted to post a new thread explaining what is going on with our washer.
Our washing machine has been acting up of late. It started with the sd error code at the end of the cycle and progressed to no code, no end of cycle light and the door still locked.
By unplugging and then plugging back in and starting and cancelling a new cycle we could get the door unlocked. The clothes would be quite wet although there did not seem to be any standing water in the drum. Doing a Drain/Spin cycle usually seemed to work to get the water out of the clothes.
After reading other forum posts and answers I did the diagnostic test. The only error code it shows is the F33 code. During the test it would get to the Normal/Casual (Drain pump is ON) step and after some time would trigger the F21 Long Drain code. The pump sounded like it was running but no water was being pumped out of the drum. I would then have to exit the test and do a Drain/Spin cycle to get rid of the water. As soon as the Drain/Spin cycle would start the water would drain normally.
I took the pump off to check for stuff in the coin catcher and to check the impeller. Upon taking the pump apart there was water in the plastic tube that the windings surround. Is that normal?
Also when spinning the impeller, it would have resistance and then spin, have resistance and spin etc.. Again is that normal. When I cleaned and dried out the tube and put the pump back together, I connected it to power and it seemed to run fine. No excessive noise or vibrations. I put it back in the washer and ran another diagnostic test and it did the same thing as the first time. Pump would not pump water out. It almost seemed that no water was going from the tub to the pump. Could the ECO valve be causing this?
Any advice is appreciated and if any further clarifications are needed let me know.
Mike in Canada
Mike in Canada
