FIXED WFW87HEDW0 Door Latch Malfunction
QtetBari
Pawleys Island, SC
WFW87HEDW0
Good evening, after loading the washer, putting in the detergent, setting the cycle, and starting the washer the door latch starts engaging and disengaging. At that point, it was flashing E03 and F05 error codes.
We've unplugged it for over an hour and tried again with the same results except no error codes. We turned it off but the door latch kept cycling.
Got the door open, removed the clothes, and tried again. Same thing with the door latch. Still no error codes.
Any thoughts or suggestions?
I've seen this before on my service calls, (F5E3) DOOR UNLOCK ERROR and that indicates your door latch lock switch will need to be replaced. Also check your door strike to make sure it didn't break off: Door Strike WPW10488048
Here's the door latch lock switch assembly for your model you can order:
WPW10443885 Latch
This is a video in this part link that shows you how to replace it: Door Latch WPW10443885 Video
QtetBari
Pawleys Island, SC
Thanks for the info, Jake!
I'll double check the strike. When I looked at it last night, it seemed intact. It did have some right-to-left play because of the slotted screw holes.
I didn't get the exact F5E3 error message, it flashed e03 and f05 consecutively.
Anyway, I'll check everything out and will let you know what I find.
Thanks again!
cbb
Correct, Fault codes are displayed by alternately showing F# and E#.
But it means F5E3.:)
QtetBari
Pawleys Island, SC
Good morning Jake,
Got the new part (wow was that expensive!) and had it installed in about 10 minutes. I put a light load in and ran the short cycle. Then, BAM! Error codes f01, e03 (I think.) After grumbling a little, I turned it off, unplugged the unit, and let it sit for an hour. Plugged it in, fired up another load, and it worked like a champ.
My bride has run 3 loads with no other issues, so I'm not sure why it threw the error code.
Anyway, unless something else pops up, I'm considering this "problem solved."
Thanks for your help!
Btw, I carefully took the old latch apart and discovered that the plunger that engages/disengages the lock was stuck. I manually unstuck it. Thinking about putting a light dab of lithium grease on the mechanism and reinstalling it to see if it will still work. Crazy?
Excellent, glad to hear the new latch fixed it.:)
I've never tried to use grease on it before, so I really don't know.
