WFW9150WW00 Whirlpool Front load washer gets to rinse cycle, fills, then stops
mdorr79
Belmond, Ia
WFW9150WW00
Whirlpool washer gets to rinse cycle, fills with water, stops in that cycle. Door lock light comes on, beeps. I've cleaned bottom filter, tried resetting the machine by unplugging it. Does not do this all the time though. After resetting, tub moves back & forth, quits, door lock light comes on and beeps. Could this be the Door/lock assembly problem?
I'm attaching your tech. data sheet below, On page 5 get into the DIAGNOSTIC TEST -->Starting Service History Mode & Diagnostic Test.
Then let us know the fault code you are getting.
mdorr79
Belmond, Ia
OK, I will and get back to you......Thanks!
