WFW9151YW00 Whirlpool Duet spin problem
ckick
Baltimore, MD
WFW9151YW00
I'm having a spin problem with my Whirlpool Duet (model WFW9151YW00). It started out not spinning some loads, but would spin others, and now it won't spin at all - and the cycle will end, even when there is time left. It doesn't even try to spin. It drains fine and there is nothing clogging the pump filter and the pump lines aren't clogged or kinked. The continuity on the pump is also fine. I ran the diagnostic test and the door locks and it spins at what I'm pretty sure is maximum speed. I replaced the electric control board and that did not solve the problem. I don't know what to check next.
Read this thread about the shocks causing this problem:
