- WFW9300VU02
- Whirlpool
- 6-10 years
My symptoms sound similar to several other Duet threads, but not quite the same (or I have multiple problems) so I am going to post.
Yesterday this unit ran correctly.
Today, (after being disconnected for a bit) it powered up correctly and started to run a cycle normally
Checking it later however, it had stalled on an F70 error.
Later, after unplugging, leaving it for a bit then replugging (why? I have no idea) fiddling a bit no lights came on when the POWER button was pushed. Just a few beeps.S
Still later, after fiddling a bit more the LIghts came on and the Counter lit up (but the cycle indicator was flashing) when I pushed the POWER button. But when pushing START nothing happened.
in this thread
www.applianceblog.com
Jake suggested testing the MCU by disconnecting the three blue wire harness ( I presume this is the three blue wire harness at the top of the MCU) and trying again.
Jake said that if the unit now appeared to be ready to run (which I assume meant it showed a Time in the display), then it was a faulty MCU.
In my case the unit did NOT appear ready to run (no time displayed)
I am back to the quick beeps then nothing.
Suggestions?
Peter
in this thread
FIXED - WFW9300VU03 Whirlpool Duet F70 Error Code
Hi everyone, We've got a problem with our Whirlpool Duet washer. Tried to start a load of laundry this morning and the washer beeped 3 times and wouldn't start and got a F70 error code. We unplugged the washer for 30 minutes, plugged it back in, and still won't start. The back lit buttons won't...
Suggestions?
Peter
