ezdrocks
- WFW95HEDW0
- Whirlpool
- 6-10 years
I have the Whirlpool WFW95HEDW0 washer. Sunday night was doing a load of Rugs and got the E01 F09 error code. I looked that up and found some good information on here. I removed the drain pump filter and found a sock and some change in there. Cleaned the filter, and put back in. I did diagnostics and cleared the codes.
I tried doing the diagnostics and pressed 2nd button to go into test mode. then pressed play. I did C00 door lock/pump test. Door locked, unlocked, locked again, and I listened for the pump...nothing.
OK, Pump is bad...so I thought. Removed the pump, tested it on my work bench by supplying 120vac to it. Pump spun fine.
OK, Possibly bad circuit board. Put volt meter on the pump supply wires and initiated C00 test again...when it got to lock, unlock, lock, TEST PUMP, I was reading 122vac on the pump wires.
Huh...weird. So I re-connected the pump to the wires and did C00 again. this time the pump spun...GREAT!!
Put it all back together. do another C00. I can hear the pump turning (no water in the tub). I move on to C02 (add water to the tub). Then stop diagnostic, re-enter diagnostic, and do C00 again. PUMP WORKS...GOOD FLOW OUT OF DRAIN LINE!!! YES!!!.
I had to do C00 a couple of times to completely drain the tub, and it works each time. Excellent, It works. I'm a hero.
This afternoon, just to verify everything, I add an Allfresh tab, and start the cleaning cycle. DUN DUN DUN!!!, Now I have error code E01 F03. I have water stuck in the drum. Great. I initiate a C00...no pump.
Please help. Do I replace the pressure switch? I blew in the hose, didn't seem blocked. I cleared the error messages and tried again, still no pump. Is it the bulb thing?
Thanks. EZD
Thanks. EZD
