WFW95HEXL2 Whirlpool duet steam problem, F06 E02 fault code
Dad
Oregon
WFW95HEX
I have a duet model WFW95HEXL2 that first had a drain clog then after cleaning out the screen and the clog in the drain line now I have a F06 E02 fault code.
When you cleaned the drain pump you may have accidentally caused a wire connector to come loose, since you didn't have this error code before you cleaned the drain pump. I'd first start by checking all the wire connections to the CCU and User Interface.
F06 E02=COMMUNICATION ERROR UI TO CCU
Communication between Central Control Unit (CCU) and User Interface (UI) has not been detected.
Possible Causes
• Verify continuity in cable between CCU (UI7) and UI (C2). See wiring diagrams.
• Check AC and DC supplies. See TEST #1 (CCU/Power Check).
• See TEST #2 (User Interface).
Here's the service manual for your model: https://www.dropbox.com/s/zz8busk3kej353k/W10372167%20L-85%20Whirlpool%20WFW94%2095HEX%20Direct%20Drive%20Front%20Load%20Washer.pdf?dl=0
