YGL
- WGG745S0FS02
- Whirlpool
- 1-5 years
Hi
I have a Whirlpool Double gas oven, model # WGG745S0FS02.
The bottom oven, the broiler (inside the top oven) and the left two burners on the stovetop work fine.
The bake cycle in the top oven does not warm up and the two right burners and the griddle burner do not ignite. I can ignite the burners with a match but the fire is tiny when turned up to high and it goes out when turned down to low.
Is there some point at which the griddle burner, right two burners and bake cycle for the top oven (but NOT the broiler, bottom oven or left two burners) share a common gas supply that might be blocked or have a faulty valve?
Thank you!!!
Thank you!!!
