What color wires goes to plug Quiet Partner I Whirlpool dishwasher DU1030XTXS1
Mikebar4
Mississippi
Quiet partner i
Control board went out on whirlpool quiet partner i. Got new board in and went to install. Plug was burnt pretty bad so I had to put terminals on each wire and plug into the plug. It’s the 4 prong plug that powers the board.
My issue is that the burnt wires discolored the end of the plug I didn’t noticed when I cut to put terminals on and now I’m faced with 4 wires and I’m not sure where each one goes. 1) solid white 2)white with red stripe 3)blue with red stripe. 4) black with white stripe
I have search to the end of the internet and can’t find a picture anywhere. HELP!!!!!!!
Added model number
We need the model number of your dishwasher first.
Read it from the model number tag, which is located inside the door on the tub frame.
I'm attaching your tech. data sheet below, but here is a screenshot I took of it and made a RED BOX of those 4 wires which are labeled by color.
Cntrl-Elec W10906417
Let us know how it goes after you replace the control board and the wires that you clean up and put new female spade terminals on to connect those wires back in place on the new control board.
  • Tech Sheet - W10292953 - Rev B.pdf
