What is this metal plate from a GE Cafe CGS990SET9SS range and where do I reinstall it?
skamp
Cypress, TX
CGS990SET9SS
I was replacing the indicator lens on the front of the control panel and two metal plates fell to the floor when I was trying to pull the control panel away from the range. I can't figure out where they go and need to reassemble the range. Only one of the holes in each plate look to have had a screw going through it. Any help here would be greatly appreciated. Thanks!
Steve
I looked through all the diagrams and didn't locate that metal bracket.
Hopefully another tech or member that has seen this before can shed some light on where it goes.
skamp
Cypress, TX
Thanks for the reply. I looked in both the parts diagram as well as the factory service manual and could not find this plate referenced anywhere. I did reassemble the range but really wanted to know if this is something import for fire block, support, etc.
Steve
