Measuring from the base of the compressor, the singular top pin is roughly 2" and the two bottom pins are roughly 1.5"Measure the compressor windings. Measure from each compressor pin to ground.
Relay wasn’t good either. Could one of these replacement relays have fried the compressor?Compressor is bad, not the relay
Yeah I wasn’t able to find oneNo, the compressor isn't "fried" so to speak. Your start windings are right at the high limit of the 3-11 ohms and the start windings are over the high limit. Too much resistance. Did you check for a short?
I have a whirpool mini fridge that stopped cooling,it has the same part number as you stated above,,jpqII 4.7 WITH TWO METAL TABS,,,i ordered what i thought was correct but i was sent a relay with only one metal tab,,,did you find the correct part and fix your fridge..please advise if you did and where to look for partsI'm trying to trouble shoot a Whirlpool WHB36S mini fridge that's stopped working. It makes a clicking noise and the compressor doesn't turn on. I took out the starter relay and it failed the rattle test. Tested it for continuity as well with my multimeter and it failed that as well.
Now the difficult part has been sourcing the right relay. The original is part number JPQII-4.7. It's a 4.7 2 pin relay with pins in position 1 and 2.
I tried these MZ92 4.7 with pins in positions 1 and 4 and the fridge still won't cool. Oddly enough with the replacement relay, the digital temperature display says the temperature is dropping, but the my laser thermometer was showing room temp and the compressor got very hot. amazon.com/dp/B07MXBL4B6
Any ideas on a suitable replacement? Would a 4.7 3 pin work and just leave one pin unused? I can't seem to find the original relay anywhere.
I also am looking for a jpq ii 4.7 relay for my whirlpool,,it has a foreign name compressor,,huwa something,,,cant find part anywhere,,,is there a part that will work,,i see many that have 2 tabs and two holes in back as mine does,,fridge is only 2 years old...is it safe to bypass relay to make sure thats the problem,,when i shake the relay it rattles ,,i ordered one from amazon but they sent one with only one tab and mine has two,,,Yes, put the wires on the same terminals.
Great idea about opening relay and using guts out of good one however how do i get relay open,,relay on my whirlpool mini fridge is jpq 2 4.7..it has two tabs..cannot locate one anywhere online,,called whirlpool and they said the part was discontunued ??Fridge is only a year old...any suggestion would be appreciatedHey jimbo. I know it's been about a week and a half since you posted, but I just stumbled upon this thread. I wanted to post my own experience with this issue in case you haven't gotten your issue resolved. Or, even if you have, this information might be beneficial to someone else in the future who comes looking for answers.
I have a Galanz 7.6 refrigerator which started making the clicking sound every couple of minutes and stopped cooling. Troubleshooted and determined that the PTC start relay had failed. Initially diagnosed the failed relay using the "rattle test" and then removed the cover from the relay and confirmed that the ceramic thermistor (disc) inside was broken into pieces. Like you, I had trouble locating an exact replacement relay. I ended up ordering a couple of relays that matched the part number I needed, but none of them matched the terminal configuration of my original relay. After some research, I determined that I could make any of the replacement relays work by connecting the proper wires to the proper terminals, but I also determined that there was a far simpler solution to the problem. The original relay had a 4.7 Ohm thermistor and the replacement relays have 4.7 Ohm thermistors. In my case, with the exception of the terminal configuration, the relays were identical. So... I opened the cover on the original relay and cleaned out the broken pieces of the thermistor. Then I opened one of the replacement relays, removed the good/intact thermistor and installed it in the original relay. Reinstalled the cover, reinstalled the relay onto the compressor and tested. Refrigerator is running and cooling properly again with the original (OEM) relay with new thermistor guts. No confusion about terminals, wiring or anything else. Simple fix.
A couple of notes: jimbo, your breaker tripped because the relay caused a short circuit. Chances are, if you open the relay and look inside, you'll find that the terminals you've connected your black and white wires to are actually connected together. If you use the approach outlined above, this obviously won't be an issue as you'll be using your original relay with the proper terminal configuration. Just make sure that the Ohm rating on your new thermistor matches the original. In my case, they were both 4.7 Ohm. That said, please note that I'm not an electrician or an appliance repair technician. My experience/advice is offered for informational purposes only and if you use my advice to try repairing your appliance, you do so at your own risk. If you don't feel confident or comfortable working on your appliance, you should hire a professional. I am not responsible if you injure yourself or anyone else.
