Where is the fuse located?
cdellinger1
Georgia
JES9750BAB17
Jenn-Air
We had a bad storm with alot of lightning last night and now the range won't work at all. We checked the socket and there is power going to the range, but the stove still won't even turn on. Could it be a blown fuse? Where is the fuse located so we can check? Any other ideas would be great! Thanks!
Yes, you'd need to turn the breaker off to it, then pull it out from the wall, then remove the back access panel and check your thermostat for continuity with an ohm meter.
Now on this model it shows two thermostats but only lists one in the parts list, so thats kinda odd. But look to see if yours has one or two thermostats.
Here's the parts diagram #14 and #32 are the thermostats:
http://c.searspartsdirect.com/lis_png/PLDM/W1006015-00004.png
