FIXED Whilrlpool GH9185XLQ0 Microwave Loss of Heating Power
gapi
N GA
GH9185XLQ0
She is not heating like she used to. Takes three times the amount of time to get the same results. What can I check?
gapi
N GA
1 cup of water begins to boil in 7 Minutes in a Pyrex 2 cup measuring cup.
Most will boil 1 cup of water under 5 minutes.
Certainly sounds like the mag has weakened and the output is not 100% any more.
gapi
N GA
I have a magnitron I purchased a few years ago that I found It was not the issue, but a bad fan motor. I'm going to try and replace it.
Where are these capacitors I need to discharge. I don't see the kind I am used to seeing but I'm no e-tech. Any pics?
gapi
N GA
Thanks Guys,
I just finished installing the magnitron and it boiled the cup of water in 3min-20sec. I believe I may have purchased the magnitron from one of the guys on this board.
gapi
N GA
Well I may have spoken too seen. The cup of water was room temp. The previous test was out of the tap and cooler.
I JUST did my test of frozen spinach before reading your reply which is always 7 minutes and it failed.
Diode? Which one? New oven?
gapi
N GA
Looks like I'm going to put her down. Any brand or vendor recommendations?
gapi
N GA
Gosh the research reviews are killing me. Nothing b ut love and hate al over the place. Rarely do I hear praise over one being quiet. Tons of complains about being loud.
I have had this one more than 10 years and love it.
How can I test the inverter board? I would not mind tossing the cost of the board now that I have the magnitron in.
gapi
N GA
OK, Decided it was apt to be scrap anyways so I went after the inverter. The only thing I can see is some burning of a wire as shown in the picks below.
Would you say its an open and shut case? Thanks!
