Whirlpool ACQ189XP0 17000 BTU Room Air Conditioner 230v went dead
Gramps74
Saginaw mi
ACQ189XP0
Really hot humid weather several days in a row. Had it on fan save and when it kicked back on it just went completely dead. Took it apart some and found what looks like a main breaker popped right off of circuit board. Desoldered is what im inferring. I soldered it back on now digital display works but nothing else.
What if i bypass relay
are you sure it's a relay and what's it for?
Could capacitor be bad?
Gramps74
Saginaw mi
So my understanding is that its a analog system with a digital interface. And digital voltage controls standard voltage via relays. 20210901_114157.jpg20210901_114215.jpg
I already know that. What does the relay in your picture control? I don't have a wire diagram for that model.
This was all I could find:
  • ACQ189XP0-wiring.pdf
Gramps74
Saginaw mi
Yah not convinced that is accurate to 1 i have. L1 is there but not L2. Per se and test sequence is not exactly as shown on mine since i have mode button controlling order of some choices.
Gramps74
Saginaw mi
Another question is there another capacitor somewhere? By the amount of connections on the 1 i see behind board im guessing no? And is are they run or start capcitors?
Gramps74
Saginaw mi
Another thing i noticed on your diagram refering to L1 and a L2 wires described as smooth and ribbed? Does ribbed mean striped?
One for the compressor and one for the fan motor. Both are start caps. The way to tell is a start capacitor is connected inline with the start windings. A run cap is connected across the start windings and the run windings. A run cap isn't really necessary for the compressor to run correctly.
No. The wire casing actually has ribs on it you can feel.
