Tom Ells
I will preface this by saying that I am no electrical wiz, but I have done a fair amount of electrical work and used wiring diagrams when working on cars. Looking at the diagram, power comes through the motor and then to the circuit board (see attached diagram). I'd assume from the diagram that when the board completes the circuit that the motor then runs. If the circuit is open at the motor, then no power reaches the board even when tries it to complete thr circuit. I tested from 8 on J2 to 1 on J1 while in test mode 3. In both On and Off, no power was reaching 8. To me, this would indicate that unless the test mode was not working, there is an open circuit at the evaporator fan since that is the only possible break point in the circuit.
Of course, testing for power at the motor itself would be the best way to determine if power is present, but I'm really hoping to avoid taking the freezer apart again if possible! Because the fan did start to work both times I took the freezer apart in the last few days, I suspect bad brushes (or some other problem) in the motor are preventing the circuit from closing and the motor from activating.
