doughb
- WTW5640XW0
- Whirlpool
- More than 10 years
Hello! I have a 10 year old Whirlpool Cabrio WTW5640XW0 washer with some kind of leak.
I recently started noticing a burning plastic smell after running a wash load. Searches led me to believe it might be the capacitor. I looked around the machine, but never noticed anything that looked out of place, but and washer still works -- washes, rinses, spins. Nothing looks burned, there were no puddles, no smoke, etc.
I looked this week, and this time I found a black liquid inside the drive belt cover, as well as some splatter on the side of the machine. At first, I thought it was some kind of oil or chemical. (Is the transmission leaking?) On closer inspection, I believe it to be water filled with bits of a degrading main tub seal, as it smells (when cooled) more like soap/softener than chemicals or oil. Also, dried bits are like a black dust, and it cleaned off all the parts with no soap at all. I think the burning smell is the rubber-filled water running over hot motor parts.
I'd run a cleaning cycle first, and the smell wasn't so bad at the end. Then I ran the machine with laundry, and the burning smell was clearly evident at the end. I think it was because the heavier loaded drum pressed down on the seal more than the lighter empty tub did, causing more water to leak out.
I think I'm right, but before I tear the machine apart to put in a new seal, has anyone else experienced this? Does it sound like I got it figured out, or is there something else I should check?
