Whirlpool direct drive spinning problem(Gearcase Replacement)
jd858us
SoCal
Model
GSQ9631LW0
I have a 6 year old Whirlpool washer model #GSQ9631LW0. As soon as the the spin cycle starts, it makes a loud rhythmic banging noise that is constant in speed (about 190 times a minute) throughout the entire cycle. The tub spins normally. There are also some powdery black filings on the floor near the rear of the washer which appear to respond to a magnet. The motor coupling was replaced a couple of months ago.
Aside from the timer sticking on the regular rinse cycle, the washer is more or less satisfactory, so I'm willing to sink some money into fixing it myself but only if it completely solves the problem. My question is how to narrow it down. I'd appreciate any suggestions.
Sounds like your gearcase is bad, here's another member with a similar thread: FIXED Whirlpool LSQ9659LW0 Noise on Spin
Yours uses the same gearcase that I posted in that thread.
Transmission 3360629
Video included in part link.
If your washer is under 5 yrs. old, You have a gearcase warranty from Whirlpool for just the part, not labor to have it installed.
jd858us
SoCal
Thanks for the quick diagnosis, doc! No second opinion needed, I assume. No such luck on the warranty, though ; purchased in Nov '02. Are there other less expensive parts worth changing too while the thing is all apart?
I always change the basket drive and clutch on all the ones I do as they all work together and both have worn as much as the gearcase over the 6 yrs. as well.
Now buying these 2 other parts can be expensive, so its better if you weigh the cost of the parts versus a new washer.:)
Here is the basket drive for your model, in case you decide to order it: Basket Drive 285792 Order now for same day shipping. 365 day return policy. RepairClinic.com
Here is your clutch assembly in case you decide to order it: Clutch 285785 Order now for same day shipping. 365 day return policy. RepairClinic.com
leoramos97035@aol.com
reno, nv
same problem, degree of difficulty
after a life of work i just retired and actually like the thought of trying to fix something as exotic as my wife's banging washer.
question, degree of difficulty for a guy who like to tinker, has the time and space?. can you estimate the time of repair? (wife wants to plan) i added up parts at about $350 which is a whole lot less that than $1100. thanks a lot!
leo
reno, nv
critical oversite noted after reviewing photos. i have the front loading duet washer so already the photos on how to access are not for my application. any ideas on disassembly for the inexperienced?.
Yes, but I would need the model# of your washer first. Its located inside the door.
reno, nv
Whirlpool duet washer front loader
Thanks for the offer to help. The model is GHW9200LQ, ser#csm0907138. Do you reccomend the same repair and pArts.
No, the one in the first post of this thread is a top load washer, yours is front load.
Its possibly one of the shocks on your model that may be broken.
To get access to the shocks remove the front access panel below the door:
You first remove the 3 bottom torx screws(all the way at the bottom next to the floor) then Remove the toe panel by lifting slightly and pulling forward.
Here's the shock absorber for your model:
Whirlpool WP8182703 Shock Absorber - AppliancePartsPros.com
Watch this video:
[video=youtube;wH8NkplXv4I]https://www.youtube.com/watch?v=wH8NkplXv4I[/video]
