Whirlpool dishwasher DU1301XTVQ5 door leak
Laura1130
Memphis, TN
DU1301XTVQ5
Whirlpool Dishwasher is leaking at the bottom of door. Small drip throughout cycle that eventually pools under door. Not sure if I need to replace seal or gasket or something else. Any advice would be appreciated.
Posted a video and photos of leak.
  • IMG_3897.MOV
G
Guest
Guest
There is a flexible rubber wiper at the lower edge of the inner door WPW10254546
Debris or food particles can get under and cause the leak. Use a toothbrush to clean between the gap
If the unit is leaning forward it will make the leak worse. Start a cycle and when the wash motor starts how far does the water level come up? It should only get to just past the heater element and not all the way to the inner door edge of the door panel
