Whirlpool Dishwasher WDF760SADM2 will not wash
jevans999
Cartersville, GA 30121
WDF760SADM2
Dear Forum,
Problem #1: No water to dishwasher. Error Codes are F7 and F9. I replaced the water inlet valve. Now, I have water entering the machine after replacing the inlet valve but the dishwasher hangs up in the wash cycle and will not wash but steps on to end step to complete cycle. Help!!!!, Surely after fixing one component, could have another part that is bad as well.
jevans999
It's a common problem with that model we have seen many times on this site. Check for 120 VAC going to the circulation motor. If the voltage is correct, here's the part you need:
jevans999
Rick,
Thanks for the information, I took the circulation pump out and discover the impeller was off the pump. Is there any where I can order a new impeller for Circulation Pump #W10816492?
Thanks Again,
jevans999
jevans999
The circulation pump was running without the impeller. The impeller had came off the pump, so in the wash cycle the dishwasher would sit in wash and then step through the remaining steps to completion.
