FIXED Whirlpool Dishwasher WDT710PAYM3 Leaking From Bottom Corners of Door
theyegis
New Jersey
WDT710PAYM3
Hi all,
I have a WDT710PAYM3 dishwasher that recently started occasionally leaking from the bottom corners of the door. I believe I know what is defective. There is a seal that runs along the bottom of the dishwasher door, right where the door meets the tub - mine is completely corrupted and has been flaking and cracking off for a while (see attached pictures - the camera is inside the dishwasher pointing out).
The issue is that no matter how hard I look, I cannot find this part on the Whirlpool website. The only two seals available are:
  1. whirlpoolparts.com/PartDetail/Seal/W10837566/4363329?modelNumber=WDT710PAYM3
  2. whirlpoolparts.com/PartDetail/Door-Seal/W10542314/2409202?modelNumber=WDT710PAYM3
Now, I suppose it's possible that that first part could fix my issue, but I'm skeptical because I can literally see the other seal completely deteriorating. The second part seems to be an unrelated seal that goes near the top, by the control board.
Does anyone know how I can get this lower door seal?
It doesn't show a lower door seal for your model:
#11 is the upper door seal
#3 is the main tub seal
Usually its the lower spray arm that cracks, then starts leaking water out the door. Have you checked your lower spray arm for cracks in it?
Here's the lower spray arm for your model:
WPW10491331 Arm-Spray
If no cracks in the lower spray arm, then look here:
Check to make sure the Pump Housing (Sump Cover) is not cracked or broken and its snapped into place properly.
Here's the Pump Housing (Sump Cover) for your model(Video Included in part link):
Pump Housing WPW10455271
Is it just me as I don't see a gasket on the bottom of the door?
Parts breakdown doesn't help as I couldn't find a live picture of the inner door panal.....maybe a gasket is attached to the inner door panal.
jeff sr.
theyegis
New Jersey
jeff sr.
You mean you don't see it in the schematics, right?
theyegis
New Jersey
Thanks for the reply, Jake. I do not notice any cracks on the lower spray arm or pump housing, and both appear to be in place properly. Any idea why that seal I've taken pictures of isn't shown in the schematics, or in the parts listing? Could it be it comes with the inner door panel?
Your pics, parts breakdown either.
Unless it only comes with the inner door panal.
Maybe call a parts depot and ask them to check the panal that they have in stock to see if the new inner panal has a gasket preinstalled on the bottom.
Sorry but all I see are gookus on the bottom of the door in your pics :(
jeff sr.
theyegis
New Jersey
jeff sr.
Unless I'm mistaken, I believe that gookus IS the gasket. It is disintegrated to the point that it looks that way.
*IF* that is a gasket, only option is that it comes with the inner door panal.
If it does not, send it back!
jeff sr.
Robert4
Houston, TX
I found this picture of the inner door panel that shows that there isn't a gasket on the bottom of the inner door.
theyegis
New Jersey
Based on some of the doubts raised by @jeff1 and @Robert4 here, I'm beginning to think that that stuff I photographed really is just gunk and not a gasket/seal of any kind (hence why the part doesn't seem to exist anywhere).
I think the most logical next step for me then would be to try replacing the main tub seal as linked to by @Jake. Please let me know if you guys think there's something else I should try first.
For sure check the lower arm and arm support to make sure nothing there could spray water directly at the door area.
jeff sr
Around the door seal?
jeff sr.
Ok, thankx!
jeff sr.
