Whirlpool Dishwasher WDT710PAYM4 burning smell controls dead
Luddy1983
Alabama
WDT710PAYM4
I'm wondering if this is similar to the problem with the WDT910 already fixed here, but...
My dishwasher started with the burning smell in the middle of a cycle (so says my wife...wasn't home). Then, it went totally dead. Didn't trip a breaker.
Is there a way to test the control panel and/or the main control board with a meter? It looks like, if I buy both, it's $500, and at that point, it's not worth it with an 8 year old appliance. Thanks for the help!
Take a look at the wires and connectors on the control. You might need to replace a few wire ends. Here's the part you need:
Luddy1983
Alabama
Thanks for this. Is there a way to see if the controls are OK? Like via a meter? I figured I'd have to buy the board, but I'm not getting anything from the physical controls (beeps or lights) either.
Absolutely, separate the console and take a look at board. You'll probably see a black burn spot on the board. It's a common repair. Check across the two element wires on the control for continuity. Since there was smoke, there's probably something obvious
Luddy1983
Alabama
it's a little worse than I thought...
Kind of what I figured. You can replace the wire ends without replacing plastic connector if you have enough wire.
