FIXED Whirlpool dishwasher WDT970SAHZ0 Leak
Water101
Brampton
WDT970SAHZ0
So a week ago the dishwasher leaked 2 days in a row. I then checked it without dishes in it and it did not leak after 5 runs. Today it started to leak again. This time I was able to run it and find the leak. It is coming from the left front corner. I tried to clean the door seal and behind the door seal. Made no difference.
When I run the dishwasher on the 1 hour cycle with heated dry for a total time of 1 hour and 32 minutes. Just after the 2 minute mark a large gush of water comes out of the bottom left corner for about 1 second. I am going to run it full cycle and see if it leaks any more time during the cycle and hopefully I will have an idea of when it leaks again.
I am thinking it could be the door seal but not 100% sure. Hoping to get a precise diagnosis so I can repair it with the correct parts.
Water101
Brampton
I did not catch when but it did leak again. Cycle still going. I did a paper test and the seal seems really good all the way around
Its usually the lower spray arm that causes the leak.
Look here:
Your model uses the exact lower spray arm:
Spray Arm W10837249
Water101
Brampton
Thanks Jake
Like always you were bang on. New part has been installed and run through 5 cycles both quick and regular without a leak. Never would have thought it was the lower spray arm but you nailed it.
Thanks again
Excellent @Water101 glad to hear the new lower spray arm fixed it.(y)
