FIXED Whirlpool dryer model WED6400SW1 stays on sensing and won't start
Lizzard3366
USA
WED6400SW1
Hi, out of no where my Whirlpool Cabrio dryer just wont start. I've tried unplugging it and checking breakers but nothing seems to be wrong. When turned on it just stays in the sensing mode and never turns on to start drying. Help!
Disconnect power to your dryer and check the thermal fuse for continuity:
If the thermal fuse ohm tests good for continuity, then check for 120 VAC across P9-2 (BLK) and P8-3 (WHT) on the electronic control board.
If the voltage is correct, here's the part you need:
You'll need a DMM that can measure VAC. Access the main board behind the console. Connectors are marked on the board:
If I have to answer the same question twice, it wastes my time. If another tech answers you, it wastes his time if someone is already helping you. You have no idea how much that pisses us off.
Lizzard3366
USA
I apologize. I really wasn't trying to be rude. I will never do that again. I'm sorry.
I did what you said about checking the main board and both were just 0.00. I also checked the thermal fuse for continuity like you said and nothing. So I'm assuming all I need is a new theral fuse?
It's all good. The thermal fuse is most likely the problem. For testing purposes only, take the two wires off the thermal fuse and short them together then see if the dryer will start. Don't leave the thermal fuse bypassed. I don't think you're checking the voltage correctly. Leave the connectors connected. You put one meter lead on P9-2 (black wire) and the other lead on P8-3 (white wire) That's supply voltage for the machine. If your meter leads are too big do this:
Lizzard3366
USA
The thermal fuse it was!!! I bought a new one and my dryer works again!!!! Thank you SOOO MUCH!!
