Vandill
- DU850SWPB3
- Whirlpool
- More than 10 years
Hi, I'm having an issue I'm hoping I can get help with. My whirlpool DU850SWPB3 dishwasher started to leak from the front right corner recently. It only happens at the very start of a cycle and then stops for the rest of the cycle. Each time a new cycle starts it happens again and then stops.
Door gasket looked fine but I went ahead and replaced it anyway and the issue has persisted. Deflector looks fine, I swapped the left side with the right side to see if that was an issue and the left still held up without issue when using the right side's deflector.
Took the front panel off to capture a video of the leak that I'll attach. I've taken off the inner panel as well to see if there are differences in the shape of the plastic, thought something might be warped but everything looks symmetrical on the inner panel and the tub corner is in just as good a shape on the right as the left. I removed the float to see if maybe it was diverting water from the spray arm since it's the only difference on the right side of the dishwasher but nope.
If I stuff a paper towel in the bottom right corner before closing the door it blocks the leak but that's not a great solution.
Any advice on this one? I thought maybe the spray arm because I've seen that recommended other places but it's only happening at the very start of the cycle and only one the one side. I'd imagine it would leak the entire time if was the spray arm.
The center cone is installed and I just double checked and it’s locked into place firmly.
I've tried a lot of things. Anyone have any suggestions on what I'm missing here?
