FIXED Whirlpool Duet Gas Dryer Model GGW9250PW1 will not start
steveski321
california
GGW9250PW1
Whirlpool Duet Gas Dryer Model GGW9250PW1 (Board model 8546219), over 15 years old, original owner, never any problems or service.
Now, when trying to start, we get “sensing” light on and the dryer will not start.
Tried pressing “More Time/Less Time/More Time/Less Time”, all lights lit up and display says 88. Nothing blinks or flashes and no “F” error codes show up.
Tested Thermal Fuse, zero resistance.
Tested Thermistor, about 11k-ohm at 70F
Tested door switch, good (light works and also tested by measuring Ohms across P1-2 (neutral, white wire) and P1-3 (door, blue wire).
Measured resistance across P1-3 and P1-4 and got exactly 2 ohms. Tech sheet says “If resistance across P1-3 and P1-4 is in the range of 1 to 6 ohms, replace the machine control electronics.” There is no explanation why this measurement requires replacing the board. Also, this board is model 8546219, which is apparently discontinued.
Can you suggest a next step? Thank you.
Access the electronic control on the left side under the top panel. Measure the voltage across P1-5 and P1-2 then measure across P1-5 and P1-3 You should have 120 VAC for both measurements.
WP8546219 Control Board
If you are getting 120 volts for both, then check your belt to see if its broken, because you have a broken belt switch that will keep the dryer from starting if the belt is broken.
Here's the broken belt switch for your model:
279782 Broken Belt Switch Kit
There is a video included in the broken belt switch part link to show you how to access it.
steveski321
california
Thank you. I have visually confirmed that the belt is fine, the tensioner is good, and the belt switch “feels” right, meaning it is up and if I push it down I can feel/hear a click. I have not yet ohm-tested the switch though.
What is the purpose of the voltage checks you describe? I know that I am getting power no problem, do these checks indicate something else? Also, I did not see these checks in the tech sheet.
You will need to ohm test that broken belt switch first to make sure it ohms good.
To see if your getting proper voltage my friend.
You can assume so right?
But its best to voltage test.:)
steveski321
california
Traced it to a failed relay on the discontinued board. Bought the relay and did a terrible job soldering it in and it works!
Excellent Steve, good job.(y)
