Whirlpool duet GHW9100LW Hold-to-Start button not pressing & clicking
chikoo
Dallas, TX
GHW9100LW
So my father in law calls me and tells me that the Whirlpool duet washer is no longer working. I go over and find that the Green "Hold to Start" is no longer pressing/clicking.
Question: Can I replace this button? How can I get to open the panel to remove and replace it? Any guides/walkthrough much appreciated.
Unfortunately you can't just replace the start button when this happens, you have to replace the user interface control board.
Here's the user interface control board for your model you can order here:
User Control and Display Board WP8181905
I'm attaching the repair manual pdf for the Whirlpool Duet washer.
Page 4-2 shows you how to remove/replace the control panel touchpad assembly(user interface control board)
chikoo
Dallas, TX
Thanks Jake.
Ouch. $308.90 for a new board on a 8 yr old machine.
Is it worth it or should I just buy a top loader for $499 ???
Arghhhh.
Yes, I know that user interface board is expensive.
The rule of thumb is if the repair cost equals or exceeds the half the cost of a new washer, then replace the washer.
chikoo
Dallas, TX
Thanks Jake. I ended up doing a band aid fix using a combination of Super Glue and 3M red tape. Essentially I used the 3m tape to hold the tab to the board(and be flexible), and superglued the Green button to the tab. Let's see how much this holds up!
Ok, usually thats just a temporary fix and will hold up a month or two, but you never know it may go longer.
Keep us posted if it breaks again.
asxn557
Toronto Ontario
Hey chikoo and Jake. Thanks for the post and the reference to the manual. With your assistance, I was able to open up the front panel and found that the tab holding the start button in place had broken away from the interface control board. The red pin, once pressed, started the washer normally, so it was a matter of getting something to line up to press that button. I used gorilla glue to fix the broken piece to the back of the start button and scotch tape to hold the button in place while putting the front panel back together. The tape didn't work quite as planned, but until the alignment fails, we're good for now. Next time I think I'll actually use a band-aid as it has better adhesive and flexibility. Cheers.
T
Tom Dee
Guest
Can't I just leave the plastic off and use a lil plastic pin to push red board button we needed? My issue is also the knob lite is off I got pointer at normal and the heavy wash lite is green I get that all lined up push start and nothing it's like it's doing nothing but it clicks kind of don't feel broken
