Whirlpool Duet WED9200SQ0 won't start F01 Error Code
boxermizer
Creighton, MO
WED9200SQ0
They dryer was working one day and the next, nothing. It lights up when I press the power button, but I get a click then a few seconds later the F01 error code shows up. I have tested the fuse and it appears to be good. I've read it is likely the control board, but its a pretty spendy part. I've read there are other things I can check, but they aren't for this exact model, so I'm a little confused on where everything is just by part name. Can someone tell me if there are other parts I can check/test or if there is a way to test the control board to be sure that is the problem before I spend the money? Thanks!
It's going to be the machine control electronics Access the control and measure the voltage across P9-2 and P8-3 (120 VAC supply voltage), P9-2 to P8-4 (120V if the door is closed and the door switch is good. P9-2 to P9-1 and press start, (120V to motor)
Main Control Board WPW10110641
boxermizer
Creighton, MO
Thank you! Do I access this control board from the top of the dryer? Do I remove it to test it? Are these numbers labeled on the control board or do I need to find a diagram to figure out what I'm to test? And do I need to remove the door switch prior to testing it? Sorry, I'm no electrician, but definitely willing to do things myself. I've changed out parts on a washing machine before, but never done this voltage testing before.
Yes, it's located on the left side.
You can go in thru the back of the connectors with your meter leads. If your meter leads are too big, use a safety pin:
Yes, here's the ones you need: Ignore P2 and P14
P9-2 to P8-4 (120V if the door is closed and the door switch is good).
No, if you have 120V the switch is good. Make sure the door is closed.
