Whirlpool duet WFW9150WW00 runs through till the rinse spin cycle than stops
chasbrunson
South bend in
WFW9150WW00
My whirlpool duet washer runs through till the rinse spin cycle than stops. Remains locked and beeps 3 times every 3 seconds and flashes the wash light
I'm attaching your tech. data sheet below. On page 5 do the diagnostics test and the Starting Service History Mode & Diagnostic Test to check for a error code.
For the tear in the front gasket you'd need to replace the bellow.
Here's the bellow for your model:
WPW10381562 Bellow
  • Tech Sheet W10252711.pdf
That's odd, does the washer fill on COLD WATER ONLY in any cycle?
You may want to UNPLUG THE MACHINE FIRST, then remove the MCU(Motor Control Unit) and look at the circuit board closely and see if you notice any burnt spots on it, IF SO then its the culprit.
Here's the MCU for this model:
Main Control Board WPW10384843
If the MCU looks good, then its possibly the CCU.
Here's the CCU for your model:
Electronic Control Board WPW10525361
Ok, sounds good.
