Whirlpool ED5NHAXNT01, Freezer and Refrigerator too warm
John Ghast
Plainfield, Illinois
ED5NHAXNT01
I have a Whirlpool ED5NHAXNT01, and a while ago the freezer and refrigerator got warm. I was thinking of replacing the cold control thermostat. Right now the refrigerator is at 50, and the freezer is at 40. The appliance is 14 years old. I replaced the defrost thermostat, but that didn't do much. I'm wondering what I should do next.
Check if the compressor is running by putting your hand on it. It should be warm not hot.
Also while you check the compressor, make sure your condenser fan is running, it sits next to the compressor.:)
John Ghast
Sorry, for not replying sooner I've been busy with a bunch of things. I put my hand on the compressor and it was warm, and the fan next to it was running. Also this weekend I noticed the freezer got down to 20° this weekend, that's the coldest I've seen it get. What should I check next?
Is the compressor and fans still running while its at 20 degrees? Or is the refrigerator dead silent at 20 degrees?
John Ghast
Ok I replaced the cold control part, plugged it in and let it run overnight. It's still only sitting at 30 F, and not getting any ice. I took a video hoping it will help you guys figure out what is wrong with it. What should I do next?
The compressor is kinda hot, like after 3 seconds it got uncomfortable for me to keep my hand on it.
EDIT: After posting this I went up stairs to push it back, and noticed the compressor and fan are now off. The freezer compartment is at 35 F.
That sounds like a sealed system issue. Unplug the machine and take the start device off the compressor and unplug the run capacitor from the start device. Here's how to check the start device and the compressor windings:
I can read your meter but I can't tell where the test leads are. If the measurements don't match my diagram, return the start device ( a start capacitor is a different animal) for a replacement.
John Ghast
Ok, When I get home I'll return the start capacitor. Also for what I'm measuring here.
This should help clean up what exactly I'm reading. The thing that bugs me is that before, with my old start device, I was able to at least freeze a bucket of water. I didn't get any ice in the ice box, and only the top layer of the water bucket froze, the inside of the freezer was at like 25 F. Now its like at 40 F, with this new start device I'll update with better readings after work. On a final note, This is actually the second start Device I've bought, I'm thinking of just buying a new fridge freezer, what do you recommend if it does come to that?
Looks like the compressor windings are good and the start device is bad. Check your old start device and see if it's also bad.
John Ghast
I'm back. It's been a while. I found my old start device and tested it with a multimeter. Pics attached. I also let it sit out overnight and I'm sure it's bad. The only problem is, I've allready bought 3 of these things and they all did worse at keeping the freezer cool then this one. Should I just buy another one, or is this not the problem?
Should I just buy this one? The multimeter says it's bad but maybe it could be something else?
Take the black test lead out of the 10 amp plug and put it in the bottom one marked COM then recheck the start device.
Are you buying the start device from a reputable site like we use here? --->AppliancePartsPros and RepairClinic, you always have a 365 day warranty on all parts.
I had a service call yesterday in Blythe, CA. and I did this same ohm test on the new compressor start device and mine read 8 ohms, and the old one didn't show any ohms. And once I installed the new compressor start device with 8 ohms the compressor on my Whirlpool for my customer fired right up and started cooling.:)
I get ALL my appliance parts from AppliancePartsPros and RepairClinic and they always work great.:)
John Ghast
The one in both your links is the correct start device. The one in your pics is not.
