ksvtwin
- ET8MHKLMT03
- Whirlpool
- More than 10 years
Hello ! my whirlpool fridge ET8MHKLMT03 has started "short cycling". sometimes it is normal... runs for 15 minutes, then off for 20 minutes. cooling is exxcellent i have checked that with a temp gun. maybe once every 2 hours, it will go into a short cycling mode. it will run (compressor and fans) for about 30 seconds. then it will shut off for 30 seconds or so. i can repeat that cycle maybe 5 times or as many as 20 times. i turned the thermostat down below normal and that seemed to improve the situation but it still does it. i feel like the refridgerant part is fine since the cooling is good. any thoughts as to what i can check ? im pretty handy but need some ideas.
also the condenser coils are clean. i maintain that and the fan is free of dust.
also: should any fans or compressor run during the defrost cycle ? i'm guessing no. thank you in advance.
