FIXED Whirlpool French Door Refrigerator - WRX735SDBM00 - ice compartment not cold enough
mjschmid
Nebraska
WRX735SDBM00
I have a Whirlpool French Door Refrigerator Model # WRX735SDBM00 that stopped producing ice about 3 months ago. I switched out the ice maker and wiring harness with the new upgraded ice maker kit for this model. The ice maker was working flawlessly until last week when it started producing ice very slow. It will only make 2-3 ice cycles per day. Prior to this it was producing 12-14 ice cycles per day.
In starting to trouble shooting the issue I noticed the temperature in the ice compartment (located inside the refrigerator) is not cold enough to produce ice efficiently according the the owners manual, its about 18 degrees and the manual says it needs to be below 10 degrees. However, the bottom mount freezer drawer is 0 degrees. The only temp controls on the refrigerator are through the digital control panel on the door and the freezer is set to 0 degrees. When I set the freezer temperature lower the freezer does get colder but the ice compartment does not.
Why is the ice compartment not getting cold enough when the freezer is cooling just fine?
Sounds like your ice maker fan may not be running.
Here's the tech. data sheet for your model: https://drive.google.com/open?id=1mkEgqVSlgucPjmKx24r0kZBoAywVNuRE
Get into Service Diagnostics then:
Do Service Test 36 - Ice Box Fan
Do Service Test 37 - Ice Box Thermistor
When you do the Ice Box Fan Test, listen for the fan sound in the ice maker box, to see if its running.
mjschmid
Nebraska
Thank you for the suggestions. I went into service diagnostics and did test 36 and 37.
I don’t notice a difference in the sound in the ice box before or after going to test 36 but it does sound like there is air moving. I’m not sure if this would be the fan and it was running before doing the test?? The panel flashes 01 when on this test. The same for test 37 - the panel flashes 01.
Also, when switching between test 36 and 37 I hear a noise as if something is moving or cycling which “runs” for about 5 seconds and then stops?
Any thoughts?
When switching from TEST 36 to TEST 37 its likely the ice box fan shutting off when you exit TEST 36.
Do you notice a temperature increase inside the freezer?
Do you have a freezer thermometer you can put in the freezer to tell me what it reads?
I located a service bulletin that says: --->The first symptom a customer notices is usually a decrease in ice production followed by noticeable temperature increase in freezer temperature and longer than normal cooling cycles.
mjschmid
Nebraska
Currently Temps are set as follows:
Freezer = -1
Refrigerator = 35
Actual temps using the same thermometer are as follows:
Freezer = 1
Refrigerator = 37
Ice compartment = 13
What repair is that service bulletin indicating?
Any other thoughts?
Your temperatures look good.
Sealed system problem, but your sealed system is fine with those temperatures.
Ok, Is there ice in the ice cube slots now, but it just won't cycle and dump them?
Or is the ice maker tray dry? If its dry you may have a water inlet valve problem. Fill the ice maker tray manually and see if it dumps the ice in about 90 minutes.
mjschmid
Nebraska
The ice cube trays fill fine. It is making ice but only about 2-3 cycles per day. Each cycle can take 4-5 hours between fill and drop which I attributed to the higher temps in the ice box - unless I am wrong about that? Not sure what other options would be causing the cycles to be so long and so few per day?
If the Ice compartment = 13 degrees it should work great, I have no idea why the temperature is rising unless your ice maker heater is sticking on at times.
Here's the ice maker kit for your model:
W10882923 Icemaker
Did you buy it from one of our two part suppliers? If so, you have a 365 day warranty on it.
AppliancePartsPros and RepairClinic, that both give you a 365 parts warranty on ALL parts they sell.:)
mjschmid
Nebraska
The first thing I did is change out the ice maker when trying to trouble shoot this, so I swapped in a new one about 5 days ago and it didnt fix the issue. I did not change the wire harness though, do you think that could be the problem?
Yes, change the wire harness too and see if that fixes it.:)
BrianM2020
Texas
Hi Jake,
I have the same model and the same problem.
I read this post and it accurately describes my problem; however, my thermometer has the icebox in the refrigerator is at 20 degrees while the refrigerator itself is at 36 and the freezer it at 0. I replaced the ice maker with a new certified whirlpool part w10882923 like you suggested, and I replaced the harness, but I am still only getting 2 or 3 ice drops a day. The ice seems to be solid all the way through but crystal clear, prior to this issue, the ice used to be a frosty white and seemed to not melt as fast in a cup of water.
I have rechecked the harness and all attaching electrical points and all are connected (as it does produce ice albeit very slowly).
I have run tests 36 and 37, both pass. I have forced defrost the entire unit, and I manually defrosted it for 24 hours to melt potential ice buildup that could block the airflow.
Do you have any further suggestions?
Thank you,
Do you hear the ice maker compartment fan running at all times?
BrianM2020
Texas
I believe so, but I am checking now. I have sat here for the past 10 minutes, it happened to cycle out a batch of ice right as I started listening. It has been running since. The main compressor kicked on and the ice compartment fan is still running.
Ok, clean your condenser coil and set the freezer control COLDER and see if it makes ice faster.
BrianM2020
Texas
Hi Jake,
I cleaned the coils, set the freezer from 0 to -5, set the refrigerator from 37 to 35 and I am still getting the same amount of ice and about the same temperature reading in the ice compartment (20 degrees). Any other suggestions?
Ice compartment should be 16 or below at all times.
Are you sure you hear the ice maker fan running, its a very distinct sound, you should definity hear it running, hold the door switch in with the door open so you can listen for it running
BrianM2020
Texas
I appreciate you questioning whether or not the fan is actually running. When I run diagnostic 36, I hear a motor spin up; however, this time I decided to run the diagnostic and pull out the ice maker assembly. Although I heard the motor spinning up (or at least that is what I think I have been hearing) the actual fan was not running. I touched the fan blade and it began to spin. It seems to have been stuck in place albeit not by anything of significance since I applied little to no pressure on the fan blade before it started spinning again. I am rechecking with my thermometer to see if that brings the temperature down. The fan continued to run as I reinstalled the ice maker assembly and I have checked it periodically and it seems to continue to be on. Does this suggest I need a new fan or fan motor?
BrianM2020
Texas
After I tapped the fan to get it running again, my temperature dropped to 13 degrees and I cycled ice about every 50 minutes. 3 cycles completed, then my fan stopped spinning. I removed the assembly and slightly tapped the fan to start it running again. It cycled a few times, but then stopped again.
