Whirlpool fridge does not dispense h2o
poster54
Tyler,Tx
ED5FHEXMB00
The water in my side by side stopped working.The ice maker/dispenser works fine.For a while, the water dispenser would work if you depressed it a little harder.I have replaced the water filter.I don't hear any noise like it is trying to work. I did remove the front kick plate to disconnect the quick connect, but was unable to disconnect it in fear that I may break it.
The most common issue when this happens on your model is the bracket support plastic switch pins break, thus no water.
You would need to unsnap(use a flathead screwdriver in the 2 little slots underneath the bottom frame piece to unsnap it) your front dispenser frame#21 here:
http://c.searspartsdirect.com/lis_pn...1180-00008.png
Then look at your support bracket#15 to see if the little plastic pins are broken that hold your ice and water dispenser switches in place#14.
Here is the one for your model, in case you need to order it:
Manufacturer part number 2180226 is RepairClinic item number 449582
2180226
<!-- / message --><!-- sig -->
