- WEG760H0DS0
- Whirlpool
- 6-10 years
Hello,
So my whirlpool oven has not been working normally for the past 6-9 months. The oven would ignite like normal, would pre-heat to temp, then would not keep temp. (I used a thermostat/thermometer in it it to check this) I would turn it off for 15 -30 secs, hit bake again and set temp then start and it would heat back up normally and work like normal. Now over the last month it wont even ignite most of the time. I will have to retry several times before it finally ignites, it would preheat to temp and not keep temp. Sometimes I would cancel it try the broiler, which would ignite without problem, however now Broiler ignites intermittently as well or not at all. After much time on youtube and searching the internet, i ordered (from appliancepartpros) a new oven spark module (W10860916) as well as igniter (WPW10324262). Sunday I replaced the spark module. And same problem continues. I have not replaced igniter at this time. Oven uses Whirlpool Direct Spark Ignition.
Stove burners work fine and ignite with no problem.
Now for some back story for further info that may help. The outlet my oven is plugged into for the electronics on it, is also downline form an outlet and and a GFCI outlet. This GFCI outlet would intermittently trip and I would have no idea why. It finally would not even reset so I thought it was bad. I replaced the GFCI outlet with a new GFCI outlet and it kept tripping, so I replaced GFCI outlet with a non GFCI outlet. Now I am thinking my oven may have been the culprit causing the original GFCI outlet to trip.
Any suggestions would be great. Thanks
I attached pics of Original spark module and New Spark module. New spark module was questionable with a few bent parts to it.
Tony
Tony
