Whirlpool GH7155XKQ
ajs602
Phoenix, AZ
I was using the exhaust fan on my whirlpool gh7155xkq micro oven to vent air from the stove. When I went to turn off the fan the button would not respond and the fan stayed on. I tried all the other buttons on the micro and none of them would respond. When I open the micro the light is on inside and the display shows the time. I unplugged the micro to stop the fan and when I plugged it back in the micro asks me to set time of day but none of the buttons respond.
I read some other posts which say there is a fuse behind the control panel. Is this correct? If so, does this sound like the problem?
Any input would be appreciated and thanks in advance.
G'day,
Yes.....no. If the fuse lets go the entire microwave will go off/dead.
Sounds like a control issue....key panal, PCBoard or both.
