Whirlpool GI5FSAXVY02 - Front display went out, Fridge quit cooling and dispensers quit working
CBCo
Tn
GI5FSAXVY02
Front display blinked a few times then went out. Fridge quit cooling and dispensers quit working. Read a few threads on what to replace. Replaced both control panel and display in front and HV control in back of fridge. All lights on front display come on when I push any button. Push lever and light and beep stay on. Any ideas?
The way it's acting sounds like a bad or loose connector. See if you can get into Options>Settings>Factory Reset.
CBCo
Tn
Not sure how to do that. When I push any button on the display , all lights and displays come on at once. Digital read out is all lit as if it were 8s....
I haven't seen that issue before but it sounds like one of the display parts is defective. Did you connect the ribbon connector?
CBCo
Tn
Ribbon is connected. Which defective part would cause all lights/display to come on when only one or any button is pushed?
Could be either one. If I had to guess I would say display board. Didn't you get both parts together in a kit so you'll need to return both keypad and board. When you get the replacement part that should solve the problem.
W10740218 Dispenser Control Board Kit
dshand
VA
Did replacing the display control board fix your issue? If not, what did fix it. I having the same, exact problem.
Dave
