Whirlpool GI5FSAXVY02 replaced dispenser trough issues
bpuhrm9
Iowa
GI5FSAXVY02
I replaced the mechanical flapper as the lights quit working and after further inspoection, I found the wires were corroded (can't just replace the bulbs). Now all the lights on control panel are on and I can't get it to work. I've unplugged the entire unit to reset and checked the program code(code is good) and still won't work.
This is all after replacing the main board, control panel board and the touchpad.
I will hold the unlock button the the freezer light will flash along with the unlock light as all other lights stay lit up.
Anything else I can try to make this work properly.
Check the wires and connectors where they go into the door. Look for any almost broken or pinched wires. Make sure the metal pins in the connectors are not backing out of the connectors.
The wire harness that comes into the door usually is located underneath the top hinge cover.
