Whirlpool Gold GSC308PJB4 micro/oven combo "door" microwave error
Boldruler
TX
GSC308PJB4
I have a very old Whirlpool microwave/oven combo GSC308PJB4. The microwave won't turn on and displays DOOR. I have looked at some of the other threads and have located the service manuals. My question is should I look at switches or fuses first?
I'm pretty green at appliance repair but going to give it a try!
Thank you!!
~Marci
The door switches.
Read this thread:
Your model uses those exact same door switches:
Boldruler
TX
I have to pull the unit out some to get to the switches, yes? I haven't been able to do that.
But now I'm getting a keypad not connected error. All the connections look fine so I'm stumped again
I think maybe I screwed up the ribbon trying to get the panel on and off.
Make sure you disconnect power to the microwave first!
This video should give you the general idea of how to do it:
Boldruler
TX
Thank you for the help. I think it's toast. It is 20 years old and I believe the keypad ribbon got damaged when I took the control panel off. :(
Shopping for a new one now.
Ok, Happy Shopping!
Boldruler
TX
Oh my gosh, I am striking out. Supply chain issues I guess. Mine cannot be fixed, correct? I cannot just repair/replace the ribbon? I would have to replace the entire control board?
Thanks for any help. On the bright side, maybe I get out of cooking Thanksgiving dinner!
