Whirlpool GS773LXSS0 range oven not working
chrispwing
Oregon
GS773LXSS0
Hello, the oven in my gas range is not lighting. When I turn it on I hear 2 clicks, but nothing else happens. I do not smell gas and the igniter does not glow. Also, the broil function does not work either.
Lets first ohm test the gas valve. You will need a multimeter to ohm test the gas valve.
Here's the gas valve for your model you can order, if needed:
WPW10293048 Valve-Gas
Its located at the very bottom of your range towards the back, so you'll need to pull your lower storage drawer out to access it, get a flashlight or droplight so you can see better under there.
Unplug or remove power from the range FIRST. Set the Ohm meter on RX300. Remove the three wires from the gas valve. The wire connectors are different sizes so they can be replaced in the same spot. The center terminal is the common terminal. Put one meter probe on the center terminal and touch one of the other terminals and then the other terminal. The meter should read 216 Ohms both times. If not, replace the gas valve.
TEST PROCEDURE
Solenoid Resistance Tests
1. Disconnect power from the range.
2. Set the ohmmeter to the R x 100 scale.
3. Touch the ohmmeter terminals to terminals 1 and 2 (Broil). The ohmmeter should read 216 Ω ±30.
4. Touch the ohmmeter terminals to terminals 3 and 2 (Bake). The ohmmeter should read 216 Ω ±30.
NOTE: Always check both solenoids. If one of the solenoids is defective, neither one will operate.
Keep us posted.
Ok, that's the problem then, order and replace the gas valve I posted the link to above and you will be back in business.:)
