Whirlpool HE Washer 110.26222011 , no spin or fill
Terry Darlene
Cabot, Arkansas
I have been working on this washer for a month , replaced lid lock , check boards and capacitors on board , looks good , replaced shift actuator , capacitor , and inlet valve . When you start it it locks unlocks locks senses and sounds like it is trying to turn tub to sense but tub does not move . no codes , have done calibration over and over < no luck >
Hi Terry,
Does the tub spin both ways when you turn it with your hand?
Look on Page 10 of your tech. data sheet where it says WILL NOT FILL.:)
Valve Problem: See TEST #2: Valves, page 13.
Main Control Problem: See TEST #1: Main Control, page 12.
Here's the water inlet valve assembly for your model: W11158805
Here's the main control board for your model you can order if needed:
W10392973 Electronic Control Board
