OK, Here is where I am.
1) I removed the consol to inspect the switches and latches.
2) Upon visual inspection there are no broken plastic pieces and all three switches look and sound fine. The switching mechanisms all seem to engage properly when the door is closed.
3) I removed the 3 switches to test for continuity. In your picture above the upper and lower switched showed continuity when the switch was engaged. The middle switch showed continuity when the switch was not engaged. I believe they are all fine.
4) I reattached everything and I still have the same problem. The micro lights up when I hit start, but I need to put downward pressure on the handle to get it to heat and have the carousel turn. I watched the switched as I applied dowward pressure and I did not notice anything getting engaged.
Any ideas for next steps?
